Introduction
uksteve
PostPosted: Wed Aug 10, 2011 9:03 am    Post subject: Re: second thoughts: Reply with quote
Chet Bishop wrote:
On the other hand, I guess if you only want to make one or two fiddles, the books and internet will take you a very long way, for very little cost.
The problem is that lutherie is addictive. At some point you will want to get good at it. By that time you may have firmly entrunched some bad habits. I have had a hard time ridding myself of some of them.
Thanks for the advice Chet.
If I'm brutally honest, if I was coming to the States for mentoring my first choice would be to go on the week long course run by Ervin Somogyi for guitar making as this is my main interest. The violin thing at the moment is just a pleasant distraction. Although, as you say this kind of thing becomes addictive so in future who knows. Actually there are a couple of well respected schools here in the UK for violin making so if I get the urge I may look at these.
You're right, of course, that it's better to have a good teacher, and as someone who teaches I would advise the same. Luthierie is for me more of a serious hobby than anything else so I'm in no rush to professionalise (if there is such a word) myself.
Again, sincere thanks for the advice so far and I hope my lack of ambition doesn't put you off commenting on my questions.
Cheers
Steve
PostPosted: Wed Aug 10, 2011 9:42 am    Post subject: Reply with quote
Nope. Not gonna ba a problem. Smile
Have you bought Mr. Somogyi's books? they are costly, but a whoooole lot cheaper than winging it to Oakland. You could call him, too. I did, and he is very approachable and helpful
uksteve
PostPosted: Wed Aug 10, 2011 10:58 am    Post subject: Reply with quote
I do have the books and as you say they aren't cheap, but they have some great insight in them. Books do have their limitations though - he talks about voicing in terms of 'ping', 'doing' etc. so I'd very much like to see him do the voicing in real life. Not sure even that can convey a lifetime of experience but if the opportunity ever arises I'll try and get to one of his courses.
uksteve
PostPosted: Fri Aug 12, 2011 6:22 am    Post subject: Reply with quote
I received the Strad Titian poster today - amazing that it actually has CT scans of the original instrument.
Thanks for the heads up about these posters, it will be very useful.
Interestingly, I've just compared the fixer-upper I got to the Titian CT scan and although its slightly smaller, it looks very similar in terms of proportion.
uksteve
PostPosted: Sun Aug 21, 2011 12:35 pm    Post subject: Reply with quote
Hi all
I've got the belly of the old violin off and it looks like I was wrong about the quality.
The inside face of the belly is very roughly carved and the are no corner blocks on the c, just strips of wood.
I've also noticed that the neck is slightly twisted now I've got the finger board off.
Do I carve / scrape the inside of the belly smooth, make and fit corner blocks, and try to straighten the neck - or toss it and put it down to experience?[/u]
PostPosted: Sun Aug 21, 2011 3:45 pm    Post subject: Introduction Reply with quote
I don't see any value in adding blocks from the inside, that's not the way to make a violin so you're not really practicing anything.
I'd practice removing/reattaching the top, remounting the neck, etc. These are things that will have value in the long run. Even practice varnishing, strip and varnish again. This takes you from theoretical to practice. Treat it like its your best friends favorite fiddle.
uksteve
PostPosted: Sun Aug 21, 2011 3:59 pm    Post subject: Re: Introduction Reply with quote
Sounds like good advice, thanks Dave.
Is there a viable way to straighten a twisted neck or do I work around the problem by re-shooting the fingerboard to compensate?
PostPosted: Sun Aug 21, 2011 4:32 pm    Post subject: Reply with quote
You can, but its always better to go to the root of the problem. You might disassemble the neck from the body and remount. If you need to raise the fingerboard projection, then glue a couple mm of maple on the end of the neck that fits into the mortise and refit to the mortise. If there's a twist to correct, you'll obviously have some gaps in the ribs where the neck joins the upper block. You can take some odd rib material (you may have to find some maple) and match and fill. But its all good practice. No sense practicing something that isn't the best choice, i.e. manipulating the fingerboard, unless of course we're just looking at a mm or so. Of course, I can say all this not seeing exactly what the problem is.
There are some good tips on removing the neck from the mortise here on this site. It'll make this old fiddle worth a little more in the long run if done right.
PostPosted: Sun Aug 21, 2011 7:38 pm    Post subject: Reply with quote
Steve... remember that the angle of the neck side to side (where the fingerboard glues on) is not always made to be parallel to the tops of the ribs. The traditional way was to have that surface angled slightly towards the treble side, but many current makers make it flat.... so maybe your neck is not twisted... just traditional?
Closeup pics would help us help you!
uksteve
PostPosted: Mon Aug 22, 2011 4:19 am    Post subject: Reply with quote
http://s1184.photobucket.com/albums/z329/yorkieyork/?action=view&current=Before.jpg
http://i1184.photobucket.com/albums/z329/yorkieyork/th_After-1.jpg
Hope these links work OK
PostPosted: Mon Aug 22, 2011 5:37 pm    Post subject: Reply with quote
I don't see enough twist to warrant making any adjustments. Like Matt says, a little lean to treble is acceptable, and the way some make them. I like the straight on neck because it allows you to cut the bridge with a little more wood under the E string. As a player I like it like that because the way I hold my violin in the orchestra -- if its cut too far to the treble side, I have to twist my body so not to have my lap in the way of playing on the E string.
PostPosted: Mon Aug 22, 2011 5:58 pm    Post subject: Reply with quote
Steve... still hard to tell exactly where the twist is...
1- if the center of the neck does not line up with the end pin ( assuming end pin is centered), then that is normally fixed by resetting the neck. That means remove neck, glue top on, find center of body, hold bridge in correct position relative to bassbar with elastic, shim and adjust heel of neck until it lines up perfectly for elevation and centering on bridge. reglue neck.
The cheap fix of that ( for a cheap violin) is to break the joint between the button and back and about 3" either side... then pull the neck to center on the end pin and reglue.
2- If the twist is the concavity of the lengthwise surface where Fingerboard is glued, then that can be starightened by wetting and clamping and gluing on a staright FB.
3-As Dave said, The side to side twist looks OK
uksteve
PostPosted: Tue Aug 23, 2011 1:33 am    Post subject: Reply with quote
Thanks guys.
Looks like I'm over critical of the amount of twist.
I'll concentrate on the other problems and try and make the best of this rough little fiddle.
Not sure I'll be able to resist smoothing the inside of the sound board though, it looks like a mountain range at the moment.
Smile
PostPosted: Tue Aug 23, 2011 9:37 am    Post subject: Reply with quote
I have smoothed them...I see no harm in that.
Does it also have an integral bass-bar? (that is, the bass-bar being carved as part of the plate, rather than a separate bar glued in place?) If so, I would seriously consider planing it out, regraduating the entire top, and installing a new, carved bass-bar. (See attached photos, wherein the first is the original plate in the condition it came to me, the second and third show the regraduated plate with a conventional bass-bar.)
You can only go so far-- if there are thin spots, you certainly don't want to make them thinner. But you can improve the sound and response, and not harm what (bear in mind) was not a valuable instrument the day it was brand new.
Those instruments were imported and sold with case and bow for about $2.50, when new. I really see no harm in the sort of correction I describe above. In the particular case of that instrument, it also required major repairs to the pegbox, as it had been badly damaged. But it was someone's great-aunt's violin, or something, and it was precious to them. They were delighted with the results, and the young man to whom it now belongs treasures it and plays it daily in a school orchestra.
BTW, if you look closely, you can see an unrepaired saddle crack threatening to become a bass-bar crack, in the upper photo. Hence the two cleats in the lower ones.
PostPosted: Tue Aug 23, 2011 11:37 pm    Post subject: Reply with quote
I agree with Chet... If it has an integral bass bar, then for sure carve it out & regraduate the top. I've done lots of them and many turn out be be quite nice sounding violins... From a market value perspective, not worth the work that went into it, but I had fun, learned with each one and if it was a sentimental instrument the owner appreciates it that much more.
Page 2 of 3
