rust-t Junior Member
Joined: 12 Jun 2011 Posts: 2 Location: North Carolina USA
Posted: Tue Jun 28, 2011 7:53 am Post subject: Putting Rosin on new hair |
Hi rust-t (Russ)
I tried this last night to put rosin on a new bow.
Use a little turpentine on a tooth brush to soften the rosin and then rub it on the hair.
Now is is a home made bow my first try and I used a piece of leather (I have no horse hair) but it worked? Has any one tried this on horse hair?
If some one has a bow to try it with it may be the way to first rosin a bow.
Let me know what every one thinks and if some one tries it let me know.
Russ
Update: tried it on my home made bow with leather in place of horse hair, it drew a tone the first try using weedwacker strings (string E) bass not Finnish yet. |
Posted: Wed Jul 06, 2011 4:30 pm Post subject: |
Sounds like a really bad idea to me. Sticky rosin with turpentine on it is likely to stick the hair together into a goopy mess. Stick with the dry rosin. As far as rosin goes, you can put it on almost anything to get a tone. Axe handle, hockey stick, piece of wooden dowel, pruning saw. Look it up on Youtube. _________________ Doug Wall
Posted: Thu Jul 07, 2011 11:55 am Post subject: |
Thanks Doug
I had not though of that, but I have no real bow to try it on.
But I agree with you on sticking the hair all it to one mass?
Thank you for the feed back
rust-t (Russ) |
1946DudeBoy Junior Member
Joined: 07 Jul 2011 Posts: 5 Location: Las Cruces, New Mexico, U.S.A.
Posted: Fri Jul 08, 2011 8:03 pm Post subject: Rosin application |
I sometimes apply 70% alcohol with a pad (the type used prior to injecting medication--available at most chemist's shops) to the rosin cake. I have found that the hairs do not stick together if I rosin-stroke in front of a fan, so that the alcohol evaporates, leaving each hair coated with rosin. I find much less flaking and powdering if I rosin this way. One needs to bear in mind that I live in humidity between 20% to the single digits, so unless you are in the Sahara, Kalihari or Gobi your results may vary. _________________ "Imagination is more important than knowledge." --Albert Einstein |
Posted: Fri Jul 08, 2011 11:59 pm Post subject: |
"I sometimes apply 70% alcohol with a pad (the type used prior to injecting medication--available at most chemist's shops) to the rosin cake. I have found that the hairs do not stick together if I rosin-stroke in front of a fan, so that the alcohol evaporates, leaving each hair coated with rosin."
So you need to carry a fan with you to gigs? Seems excessive. Rosin right off the cake works fine. If you're starting a new rosin cake, roughen the surface with some coarse sandpaper to allow the strings to break through the glazed surface. Once that's done if should work fine. Also, please note that there would be a huge difference between using alcohol and turpentine. _________________ Doug Wall
Posted: Sat Jul 09, 2011 10:40 am Post subject: |
No Doug, I do not have to carry a fan to every gig because:
1. I only seriously rosin once or twice a week at home.
2. Living in the Chijuajuan Desert climate (humidity rarely above 20%), fans are available in most civilised locations.
I hold the slightly moisturized rosin cake in the airflow (if I am at a remote location, I can use the dashboard vent of my car) until it begins to powder. I do sometimes dry-rosin during breaks in long sessions, but if you have never been in such dryness, you cannot understand how much of this dry-applied rosin winds up on my instrument, stick and my upper airway.
I am sure water can easily be used in place of alcohol but it takes much longer to dry. I once cleaned my hair with an alcohol pad, but it took hours in front of the airflow to dry sufficiently to be rosined.
My personal rationale for using alcohol is:
1. Being a registered nurse, I have a nearly free unlimited supply.
2. It cleans at least as well, if not better than water.
3. It evapourates more rapidly than water and daysbefore any other solvent, especially kerosene (the cleaning component of most furniture polish).
4. Pure alcohol leaves no residue.
I can use it to clean my rosin from my fibreglass stick, but would hesitate to use it on my rosewood sticks, and would NEVERlet it near the secret-formula varnish of my violin body. _________________ "Imagination is more important than knowledge." --Albert Einstein |
Lemuel Site Admin
Posted: Sun Jul 10, 2011 10:48 am Post subject: |
What type of rosin are you using? Brand? Dark? Light?
There are many types and brands of rosin on the market. Some are suited to environments with more or less humidity.
If you live in dry humidity, you'll want to get a rosin with more tack. For example Hill Dark rosin (for low humidity) has more tack than Hill Light rosin (for higher humidity). Using Hill Light rosin in low humidity would lead to a lot more dust (besides the cake more likely to crack). |
gavin_rossdale Junior Member
Posted: Sat Jun 30, 2012 6:47 am Post subject: |
| rust-t wrote: | Thanks Doug
rust-t (Russ) | You will need to rosin your bow frequently after the rehair until it gets worn in...just have to be patient. |
Posted: Mon Oct 22, 2012 1:24 pm Post subject: |
Interesting. Just for the fun of answering.
I re-hair, many many bows at certain times during the year.
I do have a can of ground up powdered rosin, (ground extremely fine) , that can be applied to any bow (newly re-haired or not) in a few seconds.
I use a small piece of wood with a piece of leather on one end, rough side facing out, to dip into the powered rosin can and wipe it directly on the (tightened) bow hair a few times...
It gives exactly the same result as applying the cake rosin with much rubbing does, but is much quicker. then, play the violin with the bow and wipe off the excess rosin to start. The rosin dust that winds up on the violin (not the bow hairs) that is
Using a leather strip in place of the bow hair is interesting. But it is not what violinists usually use.
OK, I'll state it simply, its not what they ever use.
In my opinion, I believe that this method is usually what I see bow craft persons in the field usually use, when they want a simple correct rosin job on bow hair and when they have to do it VERY often.
New hair, old hair, ... whatever - they just want it done, so that the bow works correctly (and quickly.)
When working on MANY bows it's simply a time saver
(I've never seen anyone use alcohol when rosining a rehair or simply old hair. I have seen people use it, when they are attempting to clean off crap from the hair - but it's a thing that must be done with a certain procedure, in my opinion, or you can really mess up the hair if you don't know exactly what to do and what not to). _________________ Look,
Lemuel Site Admin
Posted: Mon Oct 22, 2012 2:59 pm Post subject: |
Hi Craig,
Thanks for the tip. I'll have to try this out. |
Posted: Mon Oct 22, 2012 7:54 pm Post subject: |
| Lemuel wrote: | Hi Craig,
Cool. _________________ Look,
