Benedict White Member
Posted: Fri Feb 04, 2011 12:08 pm Post subject: Top thickness |
Has any one got an opinion on this article:
http://liutaiomottola.com/myth/varch.htm
According to it, Strads mostly have fairly evenly (though not entirely uniform) tops, that are thinner in the middle than at the edges. (Makes some sense given the tools he used to thickness them). |
Posted: Fri Feb 04, 2011 5:39 pm Post subject: |
| My opinion is that the article is a misrepresentation of what Sacconi said. Around 1900 the Hills' measurements showed that Strad tops were pretty even all over. Doesn't seem like news to me. |
Posted: Fri Feb 04, 2011 6:18 pm Post subject: |
Ah, I see... caught in the trap of listening to one side of an argument when in fact there isn't one...
So Strads are even all over... makes sense if I understand his graduation tool correctly, which also seems much easier to use than the modern equivalent that measures thickness. |
Posted: Sat Feb 05, 2011 10:57 am Post subject: |
There are a couple of ways to think of this problem. The easiest is that since the edges at the purfling are originally about 3.5mm thick, before any antiquing, and the center around 2.5mm on most Strads, you can't have any other situation than the center being thinner than the edges. Then it becomes a matter of how you get from 3.5mm to 2.5mm. On good violins, this doesn't happen right away at the linings--the thickness goes down gradually over a distance of an inch or two. The center is farthest from the edges, so it should be thinnest. Add that it's the part that sticks up and is easiest to scrape, and it can easily get thinner.
When this subject came up (the first printed mention of it that I'm aware of is in a book from 1937, but it's common knowledge in shops that work on this type of violin) it didn't seem like a revelation to me, just a comment on the obvious. If you look at Jeff Loen's charts, the difference he sees is often in mere tenths of a mm--not enough for the Hills, who measured in 64ths, to have noted--and it's more statistical than grossly obvious.
And that's what I thought until I measured a virtually new del Gesu that had a bathtub-shaped depression under the bridge that was 2.6mm surrounded by 3.2+mm everywhere else. So now I wonder if it was intentional, and got smoothed out over time, by a couple hundred years of "restoration". _________________ new blog at my site! http://darntonviolins.com/blog
Posted: Sat Feb 05, 2011 11:34 am Post subject: |
| Many thanks Michael, very helpful! |
DBurns Member
Posted: Wed Feb 09, 2011 10:16 am Post subject: |
[quote="Michael Darnton"]
And that's what I thought until I measured a virtually new del Gesu that had a bathtub-shaped depression under the bridge that was 2.6mm surrounded by 3.2+mm everywhere else. So now I wonder if it was intentional, and got smoothed out over time, by a couple hundred years of "restoration".[/quote]
I'm confused.
What do you mean by smoothed out?
Is it a depression that was made by restorers? |
