Suzuki 1/8th
caeman
PostPosted: Tue Sep 22, 2009 8:07 pm    Post subject: Suzuki 1/8th Reply with quote
For $10, I picked up a fixer-upper tonight from a craigslist seller.
Internal Label Info:
Suzuki
Model 900
Size 1/8
Serial No. 12719
A second label inside:
Suzuki
No. 220
Size 1/8
Anno 1982
Condition:
No take care of very well
E string is missing
Sound post has fallen
top has a crack
Bridge is missing
I will post pictures once the good camera has returned home from being out with the wife.
I am going to see what I can do to revive this little monster so my boys can play around, as well.
mr_violin
PostPosted: Tue Sep 22, 2009 10:31 pm    Post subject: Reply with quote
Go for it!! My first violin repair job was a 3/4 old violin I got for my daughter. I made some mistakes!! But she learned on it. The sound post was made of maple. Oups! But it sounded good. I glued it in too.
Oh well, now I know better!! it was fun and I still have the violin.
That was in 1996.
Have fun!!
caeman
PostPosted: Wed Sep 23, 2009 7:52 am    Post subject: Reply with quote
For the price, I couldn't really argue. If I totally screw it up, I am not out much money and I end up with a wall hanger.
The crack on the top does not appear be all the way through.
I certainly don't own a tool that can re-seat the sound post, so I will take it to the local music shop and ask them to re-seat it for me.
caeman
PostPosted: Wed Sep 23, 2009 10:15 pm    Post subject: Reply with quote
caeman
PostPosted: Thu Sep 24, 2009 3:18 pm    Post subject: Reply with quote
Okay, so my very local sources for fiddle parts don't have 1/8 bridges in stock. I guess such a tiny thing isn't too common in Butler County. My last resort is the Baroque Violin Shop down in Cincinnati. Not exactly local, but they seem to have a reputation outside this corner of Ohio.
caeman
PostPosted: Fri Sep 25, 2009 8:23 am    Post subject: Reply with quote
Given what you might be able to discern from the pictures, any suggestions on how to address the missing chip of surface and the crack?
mr_violin
PostPosted: Fri Sep 25, 2009 10:01 pm    Post subject: Reply with quote
I have the 1/8 bridge. I have 19 new ones if you like I will send you one ,no cost to you . just send me an email.
mr_violin@hotmail.com
Also looks to me the thing to do is take the top off to fix that top crack.
it will be good to get the practess.
when you have the top off there is more you may find that you could do to improve this violin.
caeman
PostPosted: Fri Sep 25, 2009 11:36 pm    Post subject: Reply with quote
Remove the top?
Hee hee...well now...I suppose I could try. This little project looks to be quite educational, it seems.
PostPosted: Sat Sep 26, 2009 12:32 am    Post subject: Reply with quote
Make your own post setter... Get a about 1 ft of coat hanger wire... Hammer one end flat to the extent that the end is almost paper thin. trim the wide edges down and that's it!
When you use it, Curl the dull end of the wire into something you can hold, shape the rest into something like a "C", stab the post in the middle with the sharp end, at about 45 degrees to the grain orientation and insert into the violin and move it into position. Remember that the grain orientation of the post (looking at the end) should be perpendicular to the grain of the top plate. The post should be vertical to the body ( you can see this only thru the end pin hole), must fit not too tight not too loose... just snug. The ends of the post must fit the curvature of the top and bottom plate where they meet. The post should be lined up with the center of the foot of the bridge (side to side) and set behind the bridge so that there is about half the thickness of the post space between the back of the bridge and front of the post. When in place just wiggle the post setter free ... and you are done.
Good luck!... Mat
BTW... I am sure the crack goes right thru... Sad
mr_violin
PostPosted: Sat Sep 26, 2009 12:58 am    Post subject: Reply with quote
Try to push down on one side of the crack. if you can see it move without the otherside moving your crack goes all the way though.
I find that it is better to fix a cracked top after you remove it.
you don`t have to ,but as you said. what can it hurt!! It is not as hard as it looks to remove a top.
There is a post on this sight that will tell you how to do that.
You may as well learn all you can on this cheep violin.
You can add new wood were the wood is missing. make the hole as smooth as you can . then make the wood to fit into that hole .
After you are all don repairring the wood I would strip off all the old finish and completly revarnish it.
Like I said, learn as much as you can. Anyway it would be harder to try to match the old finish and make it look right.
mr_violin
PostPosted: Sat Sep 26, 2009 6:40 am    Post subject: Reply with quote
That posting on "Top removal" is on page 9 about the midle of the page.
The one thing I do differnet is that I start the sepperation with a utillity knife. I have never cut into the wood doinig it this way.
I start it at the end block just to the right and work to the neck.
Then I do the same on the left side. After I have the sides don I do the end block from the inside out. Lastly I woke the neck block from the inside to the neck. I sometimes have to make a slight cut with the utillity knife on ether side of the nick from the top down.
That is the way that works for me.
caeman
PostPosted: Sat Sep 26, 2009 8:47 am    Post subject: Reply with quote
The top is now removed.
The crack in the top did go all the way through, as I now have two halves of the top in my hands.
PostPosted: Sat Sep 26, 2009 3:59 pm    Post subject: Reply with quote
[quote="mr_violin"]..... After you are all don repairring the wood I would strip off all the old finish and completly revarnish it.
.....quote]
I absolutely agree... My first restoration was a suzuki violin. It had been the subject of vandalism at a school and the right half was completely smashed into slivers and chunks. At the time my son wanted a violin so I took it to two different luthiers and both said it could not be fixed and to the last guy I said I maight piece it togethr myself... He said no problem, but "you will never make sound good enough to be worth playing" It was originally finished with something that resembles polyurethane and after the repairs, I stripped and refinished with proper violin varnish. When I was done I took it to the teacher who knew the violin and she said it now sounded better that ever!... I even took it to the two guys who said it could not be fixed and they were some impressed... one even said it was not the same violin!! That was the start of my violin restoration career!
Don't get the idea that refinishing is a good idea... 99% of the time it is not and if refinished, the value of the instrument can be lost by as much as 60 to 90% , but in this case with a poly finish and no value... refinish.
Good luck!...and BTW... glue the top back together using the zipper cleat method... its easy and gets perfect results.
Cheer, Mat
caeman
PostPosted: Sat Sep 26, 2009 8:53 pm    Post subject: Reply with quote
This may sound straight forward to others, but not me. Should I strip the finish off before putting the pieces back together? Or after the wood bits are stitched back together? In other words, would a stripping agent undo my adhesive efforts?
For all the bow and arrow making I've done, I've never had to use paint stripper, since I never had to go back and "remake" the product.
PostPosted: Sat Sep 26, 2009 10:26 pm    Post subject: Reply with quote
Do all the repairs first including assembly of the top.... Then strip & Refinish... you dont want the dirty stripper contaminating clean wood ... you want clean wood for the glue to hold well...Cheers... Mat
