Using translucence to graduate tops and backs
CT Dolan
PostPosted: Tue Sep 08, 2009 8:54 pm    Post subject: Re: Using translucence to graduate tops and backs Reply with quote
"Have you held up wood with different densities to the light?" - I've not had the chance yet.
"If one reads the table on plate thickness, given by the Hills in there book on Antonio Stradivari, you will see mentioned quite often that the tops are the same thickness throughout. " - depends upon the accuracy of the measure, or the interpretation given the measure. For some, +/- 1 mm would be pretty darn uniform, but of course in the realm of this topic that is quite a wide margin and while the Hills certainly would have certainly known so, the question is to whom were they trying to communicate, who was their audience? It was not primarily a group of makers, but rather a group of people who might have had an interest in Antonio Stradivari and his work, however those not interesting in the finer points of graduation.
Andres Sender
PostPosted: Tue Sep 08, 2009 9:03 pm    Post subject: Reply with quote
violinarius wrote:
[snip] ...you will see mentioned quite often that the tops are the same thickness throughout.
Perhaps these instruments have undergone some re-graduating scheme since then, but I find it hard to think that the Hills were amiss in this, nor do I think they were trying to lead anyone astray.
You are taking the Hill's statements astonishingly far out of context. Look at the thickness figures in the book. They are measuring to the nearest 64th of an inch, or about .4 mm. They would have called anything from 2.2 mm to almost 2.6 mm 3/32".
violinarius
PostPosted: Wed Sep 09, 2009 12:16 am    Post subject: Reply with quote
deleted
PostPosted: Wed Sep 09, 2009 4:50 am    Post subject: Reply with quote
The charts are out there. I have about 40 of Strads, myself, that I took with modern calipers. The graduations are very uneven. "Uniform" graduation is a theory, apparent intent, a relative thing. It was virtually never realized.
Andres Sender
PostPosted: Wed Sep 09, 2009 4:33 pm    Post subject: Reply with quote
violinarius wrote:
Did they not have 128th inches back then?
[snip]
IF the Hills say on quite a few instruments that the tops were even throughout, then I can only hope that they knew what they were saying, since they also say that some were uneven.
So I guess it comes down to the question of what did they mean by even, and uneven.
So you assume, and I hope!
I think you should provide exact quotes, since I am not even finding the word "even" in regard to thicknesses in the online version of the book. Laughing Meanwhile:
The only evidence* for how the Hills thought or communicated to a general audience about graduation measurements is their books. It is not reasonable to take one word from the Stradivari book and interpret it in a way which contradicts other statements in the book. The probability that the book represents a simplified or incomplete presentation of the Hills' knowledge is of no use since we have no way to determine what simplifications or omissions occurred.
So the assumptions are all on your side. The one that seems to be really clogging up the works for you is that descriptive terms about thicknesses had the same meaning for the Hills as they do for you, which is simply not warranted. Concepts, particularly those which describe relative conditions, are not handed to us by God with inscribed meanings which always stay exactly the same over time, so one has to be cautious interpreting them. A building that was "tall" for the Hills may not be "tall" for a modern Londoner.
Whatever term the Hills used, it is apparent that they did not mean to imply precision: "Neither do we find that Stradivari-or, in fact, any of the great makers-sought to obtain absolute precision in the working of the thicknesses; the whole is carefully wrought out, yet without any attempt at mathematical exactness. They were apparently of opinion that greater precision was unnecessary. "
* currently available to us.
violinarius
PostPosted: Wed Sep 09, 2009 9:06 pm    Post subject: Reply with quote
deleted
PostPosted: Wed Sep 09, 2009 9:12 pm    Post subject: Reply with quote
I suspect you haven't measured what they measured, so you don't really have an idea of how to coordinate what they said with what they meant. Here's one that's 6/64", all over: http://www.schleske.de/typo3temp/pics/31719e68c8.jpg It's so even in the context of other Strads, that it might have even been scraped a bit by someone later to even it out.
violinarius
PostPosted: Wed Sep 09, 2009 9:19 pm    Post subject: Reply with quote
deleted
PostPosted: Wed Sep 09, 2009 9:36 pm    Post subject: Reply with quote
No, I'm saying that for a Strad top it's more even than most, and the type the Hills certainly would have called even, all over, yet it still has some remarkable inconsistencies. Most are much more varied this one. I doubt very much that the Hills only saw even grad ones, so you are going to have to accept that what they called "even" is not what we might.
.4mm is quite a bit for modern makers, but what makes the effect more striking in old violins is that there can be 1.8 sitting right next to 2.6 or more, in the middle of a spot where it doesn't seem to belong. Candling is certainly one explanation of how this could have happened, but not the only one.
We don't have the opportunity to check this now: even 100 year old tops are virtually opaque to light.
Andres Sender
PostPosted: Wed Sep 09, 2009 10:20 pm    Post subject: Reply with quote
Violinaurius--What Michael said. .4 mm is exactly what I said in my earlier post.
violinarius
PostPosted: Wed Sep 09, 2009 10:23 pm    Post subject: Reply with quote
Deleted
violinarius
PostPosted: Wed Sep 09, 2009 10:42 pm    Post subject: Reply with quote
Deleted
violinarius
PostPosted: Sun Sep 13, 2009 8:00 am    Post subject: Reply with quote
Deleted
PostPosted: Mon Sep 14, 2009 6:41 am    Post subject: transluscence Reply with quote
When a maker is adjusting the thickness of a plate there must come a time when the plate resonance if just right and all the cutting must stop.This would be the main consideration.I imagine the maker would think of the internal surfaces and their appearance as "his business" and that the outer attractive finish was quite sufficient for the spectator.
Looking at the "uneven" areas of a violin plate even if you resolved the "ripples" there can still be clearly seen an overall attempt to try the effect of varying the edge to edge uniformity (or smoothly decreasing thickness) with an interesting bigger scale "design element".----These would be extensive thinner or thicker areas that show up clearly even at first glance.
Before this question is dismissed too rapidly Try to imagine what the great makers might have been trying to do.Compare the modern guitar makers way of adjusting the internal struts to give more room for bass notes to sound and a lesser more suitable area for treble notes.
The impression I get with violin sites is akin to a site where a religious belief is being questioned.Tread warily!
Andres Sender
PostPosted: Tue Sep 15, 2009 3:15 am    Post subject: Re: transluscence Reply with quote
Do you mean the resonance of the free plate? If so, there are many makers who don't pay attention to this. If you mean the projected/imagined resonance of the plate in the functioning instrument, how is the maker to know this and what signs do you imagine they would use to know it? It is likely that some important plate behaviors in a finished instrument are not resonances, how would you account for those?
What instruments do you see this in? How do you know it is intentional?
Quote:
Before this question is dismissed too rapidly Try to imagine what the great makers might have been trying to do. Compare the modern guitar makers way of adjusting the internal struts to give more room for bass notes to sound and a lesser more suitable area for treble notes.
I can assure you that many of us spend a great deal of thought on what the great makers were trying to do. Wink
Your description isn't likely to be dismissed, because it amounts to saying "making the plates the right thicknesses in the right areas will make the violin work right". Yep. But thinking about it in terms of guitar voicing theory is likely to be misleading, since the two instruments function so differently.
Quote:
The impression I get with violin sites is akin to a site where a religious belief is being questioned. Tread warily!
Okay let me see if I have this right. When someone comes into a forum, holds forth on their views with no attempt to integrate them into the context of the forum's past or subject, and doesn't receive the reception they want, it means the other forum members' views are not based in evidence? Perhaps there is another explanation.
Also, you'll find that using religion as an insult will backfire on you, as there are some religious violin makers whose capacity to pursue a disagreement past all bearing makes me look like a rank amateur. Wink
Page 2 of 3
