Experimentation
Goto page Previous  1, 2, 3, 4
PostPosted: Wed Aug 26, 2009 9:40 pm    Post subject: Reply with quote
I spent my working life as an analytical chemist. All of the published studies I have seen were flawed in one way or another. Some of Nagyvary's make no sense except that he is trying to prove his current theory (or disprove somebody else's). Others are good as far as they go, but at best the number of relevant samples is too small to mean much. "Irrefutable evidence?" To you maybe. Not to me.
PostPosted: Wed Aug 26, 2009 10:43 pm    Post subject: Reply with quote
'zactly.
violinarius
PostPosted: Wed Aug 26, 2009 11:37 pm    Post subject: Reply with quote
Geemac wrote:
There is no substitute for the mastered skill of a good maker for getting closer to the sound of the old master's work. But, there is irrefutable scientific evidence to support the application of a chemical based ground by those old masters.
So can you explain then why half the instruments tested did not have chemical grounds present?
PostPosted: Wed Aug 26, 2009 11:51 pm    Post subject: Reply with quote
I just rechecked the Raymond White study of, as the Strad magazine put it in the sub-head, "Cremonese Varnish". White checked one Seraphin (Venice, not Cremona), one Zanetto (Brescia, not Cremona), and one Tononi (Bologna, not Cremona). I had forgotten that detail. :-) But he had the most interesting discussion of anything I've read about the topic because he was so unsure, indefinite, about many of the things he might have seen. I liked the flavor of the article. :-)
Condax did good work, but I've seen some of the samples, and no way some could have even come from violins. I confirmed with a friend working around Wurlitzer at the time that some of the guys in the shop were feeding Condax things like pieces of furniture from home. So much for that.
The restorers I've spoken with agree that the layers on the Woodhouse/Barlow experiment were probably read displaced by one layer.
Nagyvary has already been discussed.
What else is there?
violinarius
PostPosted: Wed Aug 26, 2009 11:57 pm    Post subject: Reply with quote
byacey wrote:
I couldn't have said it better myself. I'd like to see an article directed towards this particular scientist asking : "Which is the real secret?"
He's cried wolf so many times only to disappear for awhile and then resurface claiming eureka all over again over something different.
In light of this, he lost a lot of credibility from my perspective. The other thing you have to consider is that he is also in the business of marketing his violins, and there always seems to be an underlying vacuum cleaner sales type pitch intermingled with his research.
If he as a Scientist made a discovery as to why Stradivari made Great instruments, then it should be over with, but the game goes on, and on.
So then a statement needs to be made that the previous claims were incorrect. Fine. So where is the article that says Science screwed-up?
Of course this all assumes that the goal is to discover what made these instruments truly exceptional, in the first place.
Anyone applying the research done in their making will have quite the mish-mash of instruments right now.
The same premise is always at work in all these discoveries, and that is that if Stradivari did it, then so could you. Nothing to it. Right? Right! Confused
None involve 'skill or talent', let alone not to mention untold countless hours spent in thought trying to gain insight into improving an instrument, or one's skills, a little here and a little there. Sweat equity costs dearly, and few have the desire or 'stick-to-it-ness' to do it in this microwave, pop a pill, hug a tree, what's next to discover, Age. Confused
violinarius
PostPosted: Thu Aug 27, 2009 9:23 am    Post subject: Reply with quote
Michael Darnton wrote:
I just rechecked the Raymond White study of, as the Strad magazine put it in the sub-head, "Cremonese Varnish". White checked one Seraphin (Venice, not Cremona), one Zanetto (Brescia, not Cremona), and one Tononi (Bologna, not Cremona). I had forgotten that detail. Smile But he had the most interesting discussion of anything I've read about the topic because he was so unsure, indefinite, about many of the things he might have seen. I liked the flavor of the article. Smile
If anyone is interested in this article, then they can find it and many more at the download section of The Strad Magazine.
http://www.thestrad.com/hdownloads.asp
Look for " Varnish: Eighteenth Century Instruments Examined
In the August 1984 issue of The Strad Raymond White looked at the then-current research into violin varnish. To download the article "
Or you can click on this direct PDF link.
http://www.thestrad.com/downloads/WhiteVarnish.pdf
Makes me wonder IF there are more of these false samples out there floating around, and IF so who else has been a victim of this?
This may help in understanding why the samples vary so much.
What else is there?
By 'read displaced' do you mean that they missed a layer?
Thanks for the most enlightening post.
PostPosted: Thu Aug 27, 2009 9:39 am    Post subject: Reply with quote
When restorers clean a violin "completely" they always leave a skin of the last layer of what doesn't belong in order to avoid touching the original varnish at all. Polish or retouching varnish has a very different texture from original varnish--smooth and glassy, as thin as possible, unbroken, textureless, content-free. Original varnish has texture and holes, and stuff in it.
Every restorer I've asked about the famous photomicrograph of layers says that the very thin top layer, that the researchers called original varnish, is a skin of polish or retouch and that the next layer down is the original varnish. So every layer from there down is misplaced by one layer. The thick layer that the researchers called the rubble layer is the restorers' colored varnish layer. The researchers maintained that the thickest layer there is the rubble layer, and is invisible to restorers! An amazing and impossible claim, but a necessary one to make the research claims fit.
There are serious problems with the study that only a restorer would catch; the researchers dismissed the restorers' opinions and observations from decades of working with the instruments--they didn't fit with their conclusions. I tried to make the ideas mesh for me, and they just didn't.
One of the more interesting things I did was make a varnish which used a very weak lake color that I made. The resulting varnish was sort of a color putty held together with varnish. The surface looked just like the remaining untouched surface on the Messiah Strad. If you looked at it under a microscope and took it apart, I imagine it would look at act like the supposed "rubble" layer.
For me, the research has too many problems to take seriously.
Geemac
PostPosted: Thu Aug 27, 2009 10:27 am    Post subject: Reply with quote
Go here and scroll down.
http://www.leroydouglasviolins.com/varnish.htm
Not every maker applied the material. It is thought that much of material was applied to prevent insect damage and some was likely used as a wood sealer/ground.
GeeMac
PostPosted: Thu Aug 27, 2009 11:07 am    Post subject: Reply with quote
Ah, yes, the bad analysis I was talking about:
The photo is there next to it.
I think you can read that page as everything that anyone at any time has suggested might be going on, plausible or not, with evidence or not. It's an overview of much that's been written about painting and varnish.
I particularly like his picture of his "latest" ground--"latest" is a step in the process. We're all still looking for The Answer, but I don't think anyone has found it.
PostPosted: Thu Aug 27, 2009 6:38 pm    Post subject: Reply with quote
If researchers would take the extra step and try to actually replicate their "findings," the conclusions would very often come out differently. I have yet to see this part of the scientific process included in any violin-related publication.
PostPosted: Thu Aug 27, 2009 7:03 pm    Post subject: Reply with quote
You know, I should have realized that. You're right. They'd have to go find another piece of wood, though. :-)
It would be better, though, if someone else replicated it rather than the original testers. I have yet to see any study replicate any other--they all get something different.
CT Dolan
PostPosted: Sat Aug 29, 2009 11:26 pm    Post subject: Reply with quote
A while ago I came across this information (the particulate ground layer bit), and something about it has never sat right with me. Nevertheless, I was not in a position to refute what I had read and took it in my usual trusting way as being representative of what actually existed. Never in my wildest dreams would I have imagined that people might have given bogus samples for study (although I always wondered how they got their hands on even miniscule scraps of authentic material).
PostPosted: Sun Aug 30, 2009 8:55 am    Post subject: Reply with quote
That incident was a long time ago, but nevertheless, you will find even today that many makers and restorers don't want you to know what they think they know.
Real, in-depth and correct information is so scarce in this business, and, worse, we don't really know what they did 350 years ago to make their violins. There are two common coping strategies: hoard, or deny the value of the information itself (or the value of those instruments). If you don't know, the best you can do is both look like you do but you're not telling, and to deny that there's anything important that you could want to know that you don't. There's a lot of that in the violin world.
CT Dolan
PostPosted: Mon Aug 31, 2009 1:03 am    Post subject: Reply with quote
It seems the best way to gauge someone's true knowledge is by virtue of their work, as in this alone is nothing left to speculation. Either it is very good, or it is not, both with regard to the tonal, as well as the visual.
Geemac
PostPosted: Sun Sep 06, 2009 9:51 pm    Post subject: Reply with quote
I've been looking at varnish recipe's and ground material and chemicals. Many of the elements found under the Stradivarius varnish also occur in the recipes from those days. Perhaps the elements and chemicals in tbhe varnish settled out of the finish as is dried and that is the reason for the thin layer of material between the varnish and the wood.
GeeMac
Page 4 of 4
