Dr. Strange Junior Member
Posted: Thu Jan 08, 2009 1:30 am Post subject: Anyone ever used one of these? |
http://www.fretlessfingerguides.com/
or have you used something similar? Do they help or possibly create a bad habit? |
kel Member
Posted: Thu Jan 08, 2009 7:23 am Post subject: |
would it be difficult/troublesome looking at music sheet and finger chart on fingerboard at the same time? _________________ Newbie Maker Kelvin |
Barry1963 Junior Member
Joined: 08 Oct 2008 Posts: 14 Location: Nashville, Tennessee
Posted: Thu Jan 08, 2009 10:05 am Post subject: |
| best to train your ear, teach yourself good habits. |
dinga Junior Member
Posted: Thu Jan 08, 2009 11:44 am Post subject: |
I guess why not.
My daugheter's instructor had color tapes put on her 1/10th violin. I thought about having them for myself, but I've tried to practice without them. Since it is easy to peel off and would not make your fretboard sticky, once you memorize a piece you can watch your left fingers to make sure they are positioning to the right fret positions.
Of course, you don't want to totally rely on it. Once your fingers are get used to all fretborad positions you can take it off.
It is sort of like those fretboard marks or dots in guitars. Almost all steel string guitars have those marks/dots on 5th/7th/9th/12th positions. Some classical guitars do not have any dots, or only one at 7th position, but most beginners would benefit from dots on 5/7/9/12th positions. Many professionals would not rely on those position marks.
I would consider the fretless finger guide similar to dots in guitars. For beginners it may help, but eventually you want to work out without having it. |
Posted: Thu Jan 08, 2009 11:30 pm Post subject: |
| kel wrote: | | would it be difficult/troublesome looking at music sheet and finger chart on fingerboard at the same time? |
True, but being new to violin I will be watching my finger placement anyway. |
Posted: Thu Jan 08, 2009 11:32 pm Post subject: |
| Barry1963 wrote: | | best to train your ear, teach yourself good habits. |
That is my biggest concern, I don't want to have to unlearn a bad habit down the road. |
Posted: Thu Jan 08, 2009 11:38 pm Post subject: |
| dinga wrote: | I guess why not.
Yes, the fact that it doesn't actually stick to the violin and can just be taken off on a whim makes it easy. That and it's only 10 bucks. I guess once I decide on an instructor I will see what he/she thinks. |
caeman Member
Posted: Fri Jan 09, 2009 12:04 pm Post subject: |
| I gotta say that I like the idea of this as a learning aid. For example, I already know Amazing Grace from playing it on my guitar and harmonica. I know the notes. This finger guide could help someone like me begin to learn the fingerings in a visual way. I am a visual-hands-on learner. |
dinga Junior Member
Posted: Mon Jan 12, 2009 11:02 pm Post subject: |
I actually got it today.
It works quite easily. It wraps around the neck and stays there without using any adhesive.
The position marks work pretty good, at least better than my fingering.
The dotted positions are a bit sharp on my violin, so I tried to position right behind each dot.
Hope this position marks would help more rather than hurt, and graduate from it soon.  |
Posted: Tue Jan 13, 2009 1:08 am Post subject: |
| Thanks for letting us know Dinga. Please give us an updated review of it after you have used it for a bit. |
Becky Senior Member
Posted: Tue Jan 13, 2009 10:08 am Post subject: |
Dinga pointed out the problem I've encountered with these. They're generally accurate, but slight variances in violins can cause the markings to be sharp or flat different instruments. I've used them a few times with students and found it best to tune the violin, play my first finger, and use that as an indicator of where the first marking should go. The top of the sticker doesn't always line up exactly with the nut when it's in tune. They're generally accurate though.
I liked using them with my students, but now I use stickers as it's cheaper. I like how quick the big "sticker" with all the markings is to put on and how easy it is to take off. I like stickers because most of my students don't need all the notes marked (or I don't want them to have every note marked) and I can mark the ones they need help with while leaving the other ones unmarked to force them to use their ear. I find that stickers or aids such as this are a benefit with beginners as they learn correct finger placement from the start (no guessing) and they also cut down on frustration as the student can visually see where the finger is supposed to go while their muscle memory develops. Stickers should not be used in place of using one's ear. I want my students eyes on their music and not relying on the stickers. I also make sure that we work on developing their ear. |
dinga Junior Member
Posted: Fri Jan 23, 2009 6:49 pm Post subject: |
After using over a week, I found that I can live without it.
It stayed on the neck pretty solid for first week, but after that I felt a strange buzz. When I removed it the buzz was gone. I may need to rewrap it tight every week or so.
But overall, it helped my finger position and I can now hear better if each note is correct or not. |
Charisa Junior Member
Posted: Wed Mar 11, 2009 10:30 pm Post subject: |
| I used a different version from www.violinstickers.com. My teacher positioned the stickers for me, so I knew they were in the right place for the note. Plus-she only let me use the note labeled ones at the beginning-now I can only use the blanks. I know lots of teachers object to the stickers, but I'm still very new to violin and find them helpful. |
mshikibu Guest
Posted: Sun Mar 15, 2009 12:01 pm Post subject: |
I have yet to find that violin stickers page. Is it still up and working? URL, again??
As far as fingerboard tapes are concerned, it *is* very controversial. When I was a young person first studying the instrument, my teacher did not use them, looked down on people who did, and I adopted that stance. As a teacher, however, I do use them.
I have a section on this in the Violin/Viola FAQ. Please see:
(33) Do you use fingerboard tapes with your students, and if so, what kind of tape?
http://beststudentviolins.com/PedagogyTech.html#33 |
