My violin build
Goto page 1, 2, 3 ... 15, 16, 17  Next
MikeCooper
PostPosted: Sun Nov 12, 2023 3:28 am    Post subject: My violin build Reply with quote
I am about to begin violin build number two. Starting off with a picture of the results from the first build. Showing back, belly, sides and scroll. And my little gnome mascot.
PostPosted: Sun Nov 12, 2023 12:53 pm    Post subject: Reply with quote
Unlike your form post, these are tiny and unreadable. Can you make them larger?
MikeCooper
PostPosted: Sun Nov 12, 2023 10:10 pm    Post subject: Reply with quote
Hi Michael. I'll try to repost better photos.
MikeCooper
PostPosted: Sun Nov 12, 2023 10:13 pm    Post subject: Reply with quote
Let's see if this works. This is the back of the one I recently finished. I'm using a website called postimage.cc to store the images. If this works, I'll post front, sides and scroll.
PostPosted: Mon Nov 13, 2023 9:39 am    Post subject: Reply with quote
That works. Thanks.
MikeCooper
PostPosted: Mon Nov 13, 2023 1:25 pm    Post subject: Reply with quote
Ok, here are a few more pictures of my first build. I think it turned out ok for a first, although there are certainly areas for improvement.
I tried to do a little lite antiquing without going overboard with it. I have no experience in antiquing and didn't want it to look amateurish.
I didn't notice a crack in the pegbox until after the neck was glued to the body so I glued the crack and installed cheek patches for extra strength.
MikeCooper
PostPosted: Fri Nov 17, 2023 6:42 pm    Post subject: Reply with quote
As usual, I make slow progress. Here's the P form half way completed. I still want to put a veneer on the other side. This side is complete except for putting some kind of finish on it. Probably I'll use some dye and some linseed oil.
For a ground I like to use horse/rabbit sauce and fustic for some golden tone. I don't make the sauce since I don't have a horse or a rabbit. Someone sent me a sample.
I spent the day reading Librum Segretti de Butega, it's very interesting.
PostPosted: Sat Nov 18, 2023 8:48 pm    Post subject: Reply with quote
You might consider changing the upper block to a more modern 60 x 18 mm dimension since the original wasn't going to have a neck block set deeply into it. Nice form.
MikeCooper
PostPosted: Sun Nov 19, 2023 11:55 am    Post subject: Reply with quote
It's 60 mm wide but only 12mm deep. I can deepen it to 18mm.
That makes me wonder about original Strads. Has the neck block been replaced with modern size on most of them?
If so then how does that work with the original glueing surface of the top and back plates? The original glue surface of the plates would be shorter wouldn't it?
PostPosted: Sun Nov 19, 2023 12:48 pm    Post subject: Reply with quote
There's plenty of room inside for a new block, and most classical period violiins don't have their original--I've seen maybe five or six, only. A lot of people try to get quickly down to 2.5mm, whatever the upper bout is, as fast as possible away from the block, but that's not how these violins are. The grads all around the edge are gradual decreases. Nothing is gained by cutting wood away as much as possible towards the linings and blocks.
MikeCooper
PostPosted: Mon Nov 20, 2023 4:32 pm    Post subject: Reply with quote
I deepened the neck block mortice to 18mm and finished veneering the back side and put a lite application of dye. It's a watered down dye and only gives a hint of color.
I don't know if I'll get to work on the end blocks and corner blocks this week with Thanksgiving holiday activities but I'll get those done soon and post pictures.
MikeCooper
PostPosted: Tue Nov 21, 2023 4:33 pm    Post subject: Reply with quote
Nearly finished. Applied a lite stain, not enough to harm the chatoyance. I may finish it with shellac or maybe linseed oil.
Blocks soon...
MikeCooper
PostPosted: Sun Nov 26, 2023 4:34 pm    Post subject: Reply with quote
I started preparing some rib blanks, just smoothing the surface for now. They are still 1.5mm thick so I'll have to thin them down some more.
Here's a link to my youtube video.
https://www.youtube.com/watch?v=Eg0OfVK4jF8
MikeCooper
PostPosted: Mon Nov 27, 2023 3:51 am    Post subject: Reply with quote
Making some corner blocks.
Youtube link.
https://www.youtube.com/watch?v=DMdLk5mR_-g
MikeCooper
PostPosted: Mon Dec 11, 2023 12:23 pm    Post subject: Reply with quote
Planeing ribs to the final thickness.
https://www.youtube.com/watch?v=nXV2AbOH13Y
Page 1 of 17
