Stabilizing old spruce
PostPosted: Sat Apr 02, 2016 5:59 pm    Post subject: Stabilizing old spruce Reply with quote
Im rebuilding an old factory violin labelled Mathias Thier in Wien 186x. Had a hairball the size of a nickel. Many earlier repairs inside the top. The wood is so fragile, I think the top is nearing its end. Thinking of coating it with something to give it some additional life. Recommendations?
Thinned clear shellac?
Thinned lacquer?
Egg white?
PostPosted: Sun Apr 03, 2016 8:12 am    Post subject: Reply with quote
Don't! I've seen this several times and had to remove it each time to do more repairs because the coating was in the way or had failed.
in the worst case someone had used hide glue over the whole inside and the top distorted. In another case someone had lined the edges with glued in layers of silk which made a mess and had to be taken out just to get to the wood underneath. Both shellac and lacquer will repell further gluing of cleats or patches.
If you feel the need to do something, use very thin reinforcing studs carefully fitted only where they will do the most good, and don't line their edges up or you will create a stress riser and cause new cracks.
Probably, though, leaving it alone is best: unless there's a strong tonal problem to correct, you may create one, instead.
PostPosted: Sun Apr 03, 2016 9:44 am    Post subject: Reply with quote
Thanks Michael. It had an ugly dark film all over inside top, most of which I sanded off. Cleats installed long ago dropping off, glue had released from the wood, perhaps as you said someone long ago sealed the interior with something causing the condition. No idea of tone, its been in pieces for many years.
