Posted: Sat Jun 21, 2014 9:10 pm Post subject: JOHA powder varnish color - soluble in Turpentine |
Anyone use the powdered JOHA varnish colors? I recently added some "brown" to a varnish to deepen the color a bit, and it was so full of small bits of trash, like I shook my bench duster over it, I ended up taking it all off with turpentine on a rag. I then put a coat without the powdered JOHA varnish color, and it was clean with no specks at all. So its clearly in the varnish color. Is there a method to using this stuff that I'm missing, or is this the way it will always turn out? _________________ Dave in the Blue Ridge
Posted: Sun Jun 22, 2014 6:01 pm Post subject: |
I'm not sure it is JOHA, but I have a couple of powders from the old International Luthiers Supply. The maker is not identified, but it does have a certain amount of insoluble residue. More significantly, I have found it to be not very light fast so I don't use it any more.
I would recommend testing for light-fastness before anything else. If it passes that you might be able to allow the crud to settle before use. |
Posted: Mon Jun 23, 2014 11:54 am Post subject: JOHA |
I got an email from the manufacturer, and now I know why they put "soluble in Turpentine" on the label....you're supposed to dissolve it in Turpentine first, then add it to the varnish. I suppose you can let it settle if it doesn't disolve. They recommend balsam turpentine.
so that answers the question! _________________ Dave in the Blue Ridge
