Builtbynick Junior Member
Posted: Wed Oct 17, 2012 11:59 am Post subject: Making a mold |
This will be my first attempt, after reading several books and doing research to make a violin, so please excuse my nievate. I drew an outline of the bottom plate of the violin I wish to copy and want to create a mold for that instrument. Common sense tells me that mold has to be a bit smaller so that the violin plate overlaps by...I would guess 3/32" to 1/8". My guess is that the procedure would be to make a copy of my violin plate outline and find the exact center of one of the corners and use that as the guide to draw it out by hand. Is this the usual way or is there a better procedure to accomplish this?
thank you _________________ Amateur violinist.
Woodworker, wood carver. |
Joseph Leahy Member
Posted: Wed Oct 17, 2012 12:11 pm Post subject: Re: Making a mold |
| Builtbynick wrote: | This will be my first attempt, after reading several books and doing research to make a violin, so please excuse my nievate. I drew an outline of the bottom plate of the violin I wish to copy and want to create a mold for that instrument. Common sense tells me that mold has to be a bit smaller so that the violin plate overlaps by...I would guess 3/32" to 1/8". My guess is that the procedure would be to make a copy of my violin plate outline and find the exact center of one of the corners and use that as the guide to draw it out by hand. Is this the usual way or is there a better procedure to accomplish this?
thank you |
An approach that many use is to first purchase a violin poster from the Strad http://www.orpheusmusicshop.com/. Although they cost a bit, they do provide the outlines and all other measurements, archings etc that you will need to build your first violin. The poster, along with the book "The Art of Violin Making by Chris Johnson and Roy Courtnall" would be the first two investments I would make before starting.
Hope that helps.
Joe _________________ ___________
Website: www.leahyviolins.com |
Posted: Wed Oct 17, 2012 1:11 pm Post subject: |
| Joseph Leahy wrote: | An approach that many use is to first purchase a violin poster from the Strad http://www.orpheusmusicshop.com/. Although they cost a bit, they do provide the outlines and all other measurements, archings etc that you will need to build your first violin. The poster, along with the book "The Art of Violin Making by Chris Johnson and Roy Courtnall" would be the first two investments I would make before starting
Hope that helps.
Joe |
Thank you for your advise.
I do have some of the posters you mention and will probably wind up using one of them because the the measurements you mention, but unfortunately I can't afford to buy the book at this time. I already have several books on the subject..."The Technique of Violin Making" by H.S. Wake and "Violin Making as it was, and is" by Ed. Heron-Allen. I might be wrong but I don't recall the subject as to how to create a mold outline from a bottom plate outline mentioned. _________________ Amateur violinist.
Joseph Leahy Member
Posted: Wed Oct 17, 2012 2:02 pm Post subject: |
| Builtbynick wrote: | Thank you for your advise.
I do have some of the posters you mention and will probably wind up using one of them because the the measurements you mention, but unfortunately I can't afford to buy the book at this time. I already have several books on the subject..."The Technique of Violin Making" by H.S. Wake and "Violin Making as it was, and is" by Ed. Heron-Allen. I might be wrong but I don't recall the subject as to how to create a mold outline from a bottom plate outline mentioned. |
Perhaps you could find the Johnson book in the library and/or, if that one is too expensive, rather than the two books you have, which are somewhat dated and are not the best resource in my opinion, the Stroeble book "ART & METHOD OF THE VIOLIN MAKER by Henry Strobel" may be a better and cheaper alternative. Also, I am sure you are aware of the wealth of information that can be found searching through Google.
MATT posted details of his first two violin builds. These posts are pretty detailed and work off the strobel book. May be worth taking a look. http://z11.invisionfree.com/Stringed_Instruments/index.php?s=39fa17606632657a1f7156450df53047&showtopic=16&st=0&#entry83789
Good luck.
Posted: Wed Oct 17, 2012 2:57 pm Post subject: |
To work from an outline you need to draw a line inside the outline, 2.5mm (overhang) + 1mm (rib thickness) =3.5mm. Because things tend to grow, thanks to pencil line thickness, 4mm even is probably a good number to really use. Then at the corners you need to draw it all in with the real rib thicknesses and the length of the miter as it will actually be. If you do that, you'll see that corners that are simply measured in from the outline won't work, and get much longer than you intended, so you need to turn the curves inwards, stubbier a bit, to make the corners, and also remember that the margin on the corners is very slightly larger than on the rest of the violin. You can get the idea here: http://www.flickr.com/photos/mdarnton/5719675576/in/set-72157626719359016/
and here: http://www.flickr.com/photos/mdarnton/5719122885/in/set-72157626719359016/
This might be helpful, too: go to http://violinmag.com and look for the article on Stradivari corner blocks. _________________ new blog at my site! http://darntonviolins.com/blog
Posted: Thu Oct 18, 2012 8:22 am Post subject: |
Thank you all for your valuable and much appreciated advice. I will begin my work and share my progress with you.
From time to time, I may ask for more advice as my project continues. I hope you can bear with me as this is my first violin.
Thanks again. _________________ Amateur violinist.
Posted: Thu Oct 18, 2012 9:20 pm Post subject: |
| Builtbynick wrote: | Thank you all for your valuable and much appreciated advice. I will begin my work and share my progress with you.
Thanks again. |
First violin?
Very cool.
Ask away. Serious new makers are the life's blood of a busy and interesting 'forum' _________________ Look,
fjodor Member
Posted: Mon Jan 28, 2013 5:32 pm Post subject: |
Just wanted to say thank you for the pictures and info, I happened to see this post and printed and used the scroll as a template for the neck i'm working on now.
Here's a picture (if I manage to attach it)
[/img] |
Posted: Mon Jan 28, 2013 11:08 pm Post subject: |
Ah, Fjodor!
Whyja hafta show that?
I have never come close to making a scroll that perfect. Now I'm gonna feel all inadequate.
Great work, Fjodor! _________________ Chet Bishop
pmccombs Member
Posted: Tue Jan 29, 2013 2:50 am Post subject: |
| Chet Bishop wrote: | Ah, Fjodor!
Great work, Fjodor! |
Hey, I went to your gallery and saw some really great scrolls there. I have no idea how people can carve a scroll as smooth as fjodor's, though. It's amazing. |
fjodor Member
Posted: Tue Jan 29, 2013 4:20 am Post subject: |
Much thanks for the kind words!
I have a question regarding fluting on Stradivari scrolls.
http://www.kevinleeluthier.com/stradivari/Harrison_Scroll_4.jpg
If you look at this picture of the back of the Harrison stradivari from 1693;
the fluting looks quite shallow and seem to be cut with a small radius gouge, is this style something that is consistent with most strad scrolls or does it vary with different periods/models? |
Posted: Tue Jan 29, 2013 10:18 am Post subject: |
Strad scrolls fluting is flattish in the middle, then curls a bit tighter towards the center spine and the bevels. The best way to do this is to use a smaller gouge for the curled areas and clear out between them with a flatter one, sort of in stages. Some people start with four lanes with a small gouge, and then clear out between each outer pair, but I work it all down together, switching gouges as needed. _________________ new blog at my site! http://darntonviolins.com/blog
fjodor Member
Posted: Tue Jan 29, 2013 5:36 pm Post subject: |
| Thanks for the information. I tried to do something like that on this scroll so it seems like I was on the right "path" at least. |
fjodor Member
Posted: Wed Jan 30, 2013 4:27 am Post subject: |
Builtbynick, since the thread went a bit off the original topic I want to post a link to a Strad article by John Dilworth, that I found helpful. It's about making a mold from a poster.
http://www.skyline-apa.com.au/Family/Violin/Stradposter.pdf[/url] |
