johngia Member
Posted: Tue Feb 28, 2012 9:31 am Post subject: Shellac Ground |
How many coats of 1 pound cut will effectively seal the wood for oil varnish? I've used shellac ground before with 2 to 3 coats, but wondering if one coat is sufficient.
Thanks. |
famuswood Member
Posted: Tue Mar 13, 2012 10:30 am Post subject: |
You might do well to read what Michael Darnton has written on the subject. Toward the bottom of his online material on violin varnishing he discusses shellac and the ratio of alcohol to shellac he recommends. Good luck.
http://www.darntonviolins.com/violinmagazine/book/varnishing.pdf _________________ I love the feel of wood in my hands - the smell of fresh cut lumber and the challenge of a difficult woodworking project on a sunny day . . . |
johngia Member
Posted: Thu Mar 15, 2012 1:14 pm Post subject: |
Thanks famuswood for the info. I wish I would have read that years ago. I am just finishing up 17 and 18. Started 19 and 20. I am going to keep making until I get a finish I'm happy with! --- (And Thanks Michael for the article) |
Joshua Blevins Junior Member
Joined: 02 Mar 2012 Posts: 2 Location: Colorado Springs
Posted: Wed Apr 11, 2012 11:32 pm Post subject: |
if you haven't attended Michael's workshop either I strongly recommend it _________________ http://www.jbblevinsviolins.com/ |
gacho Junior Member
Posted: Fri May 25, 2012 3:43 pm Post subject: |
| just go to a lumber store and buy the 3lb cut shellac and go quick on the strokes ,"It's not VARNISH!" don't thin it ,it'll seep further into the wood. if it's to thick, sand paper it. |
gacho Junior Member
Posted: Fri May 25, 2012 3:51 pm Post subject: |
Posted: Sat May 26, 2012 12:00 pm Post subject: |
If you use unthinned shellac you have a high chance of getting burned-in effects in end grain areas.
The tendency toward splotchiness due to differing absorbency of the wood is why even in furniture it is recommended to put a 'spit coat' down when using shellac as a finish.
...and I heartily 2nd the recommendation to attend Michael's workshop. _________________ You can only connect the dots that you have. |
Posted: Tue May 29, 2012 10:47 pm Post subject: |
| I recommend not to buy commercial liquid shellac... Buy the pure flakes and dissolve your own... cheers, Mat |
