bridge spreader
F-holelvR
PostPosted: Thu Dec 10, 2009 3:31 pm    Post subject: bridge spreader Reply with quote
I'm fitting the feet on a cello bridge and i usally don't use a bridge spreader becuase i'm not sure what the correct tension should be. if you don't use the spreader right you end up with your bridge feet slightly off.
What's the correct tesion or how many turns should i give it?
emviolins
PostPosted: Thu Dec 10, 2009 6:21 pm    Post subject: Reply with quote
Hi, To simulate the load of the strings on the bridge, use a bridge spreader or even a stick to spread the base of the feet 1 to 1.5mm.
actonern
PostPosted: Thu Dec 10, 2009 7:15 pm    Post subject: Reply with quote
Michael Darnton has posted elsewhere that he spreads them "as far as I can get away with." Little chance of going too far, in other words.
E
F-holelvR
PostPosted: Fri Dec 11, 2009 2:47 pm    Post subject: Reply with quote
would you take that measurement from foot to foot?
actonern
PostPosted: Fri Dec 11, 2009 4:13 pm    Post subject: Reply with quote
Yes, from the inside bottom edge of one foot to the other...
