James k Junior Member
Posted: Mon Jan 12, 2009 12:14 am Post subject: First attempt, from a woodworker |
Hi,
I am a wood worker and this was one project I wanted to build for a while so I thought I might share with you all my progress and look for pointers.
I made the mould, blocks and have assembled the frame.
Its all clamped up right now.
I use another forum for wood working and we have a Gallery of pictures we can pull from and post to. So how does it work here.
Thanks,
James K _________________ "I" am a lifetime of education and experience, culmenated into the present man. Knowing this I step out side the "I" and truly know that other's are but the same. No "I" is right or wong just culmenated in a different way.
Author Unknown. |
Posted: Mon Jan 12, 2009 8:06 pm Post subject: |
You can use imageshack to host images:
http://www.imageshack.us/
--but on the page which gives you links for the resulting image, go to the bottom and chose 'advanced linking' and then use the bottom link choice, the one they tell you not to use for forums.
Then when you are typing up your post, click the 'Img' button once, paste in the url for the photo, then click the 'Img' button again, and you should be all set. |
