Chris Knowlton Member
Posted: Sun Nov 02, 2008 6:44 pm Post subject: Neck question |
I am beginning work on the scroll and I have a question. I’m using the Johnson/Courtnall book (Newark method). The book says to cut the heel end of the neck at 85 degrees. Every other book I have shows it to be cut at 83 degrees or 83.5 degrees. When the neck is installed in the body I assume that the angled end of the heel should be parallel to the ribs (mortised of course, but parallel). I assume that the neck is always set at the same angle but that the neck is raised or lowered to achieve the correct distance from the top plate. If this is true then one of the angles must be incorrect. Which angle is right?
Thanks,
Chris _________________ I make sawdust mostly |
Posted: Sun Nov 02, 2008 7:08 pm Post subject: |
There are differing opinions on this. The Sacconi/Wurlitzer method is an 87 degree angle. That results in the back of the heel being deeper by exactly the amount of the overhang on the front--so that when you place the new neck on the body before any cutting, it's sitting at its final angle, and you can get a feel for how it's going to look.
You don't see too many good violins with the bottom of the heel parallel to the ribs. Most of the stress is at the back of the heel (at the front, the stress is compression, not tension, holding the front of the heel in, not pulling it out), and if it isn't taken by the block, by being deeper there, it's going to the button, and the button is something you don't want to see break off. |
Posted: Sun Nov 02, 2008 7:34 pm Post subject: |
So, 85 degrees would cause the button end of the heel to be set deeper into the upper block than the fingerboard end of the heel, and the greater depth at the button end gives more strength (in tension) because the mortise is more exaggerated (?)
Posted: Sun Nov 02, 2008 9:32 pm Post subject: |
| No, I think that would result in a set that was almost parallel with the ribs. Not deep enough at the back, anyway.... |
Posted: Mon Nov 03, 2008 10:33 am Post subject: |
Sorry, yes 87 degrees. The closer to 90 degrees the further the back of the heel is set into the block.
Posted: Wed Nov 05, 2008 5:29 pm Post subject: |
OK I'm going to get these numbers straight yet. The general range seems to be between 83 degrees (not 87) and 85 degrees. It seems that 83 would make the heel parallel to the face of the ribs. 85 degrees would allow the back of the heel to be positioned deeper into the mortise than the front of the heel. Yes? _________________ I make sawdust mostly |
violinarius Member
Posted: Wed Nov 05, 2008 8:34 pm Post subject: |
| You seem to be having trouble visualizing this, may I suggest a pencil and paper, along with a compass to draw a life size drawing as an aid. |
Mark Sullivan Junior Member
Joined: 13 Apr 2008 Posts: 18 Location: Orland Park Illinois
Posted: Thu Nov 06, 2008 9:58 am Post subject: |
[quote= "Chris Knowlton"]So, 85 degrees would cause the button end of the heel to be set deeper into the upper block than the fingerboard end of the heel, and the greater depth at the button end gives more strength (in tension) because the mortise is more exaggerated (?) [/quote]
[quote="Michael Darnton"]No, I think that would result in a set that was almost parallel with the ribs. Not deep enough at the back, anyway....[/
quote]
I understand the process and the reasoning behind it OK. I’m looking for clarification on the heel angle. I originally thought that 85* would give just the right amount of extra mortise depth to the back of the heel. Michael suggested that 85* would make it parallel to the ribs. The other common heel angle is 83* which would reduce the depth of the mortise at the back of the heel. Michael knows his stuff so it confused me.
Posted: Thu Nov 06, 2008 10:53 am Post subject: |
The differences are slight, but if you're going to take advice, I suggest you do what the better professional shops do, not what amateur violin makers write in their many books.
I did reset a neck with a parallel mortise yesterday. Obviously the person who did it sensed he was doing something weak, because he set the front in 2mm extra to compensate, cutting too far into the top and weakening the block as well. (And his neckset didn't work, tonally, either, but that's another story. . . ) |
M.Lange Member
Posted: Thu Nov 06, 2008 11:30 am Post subject: |
| Michael Darnton wrote: |
Obviously the person who did it sensed he was doing something weak, because he set the front in 2mm extra to compensate, cutting too far into the top and weakening the block as well. |
I did the same on my first violin.
Just because I didn't know...
So I put that on my "to do" list for the next one.
Thanks for explaining.
Matthias |
Posted: Thu Nov 06, 2008 10:52 pm Post subject: |
Hi Michael.
I’m not questioning your method. As a new builder I embrace and follow your methods and suggestions. I understand, after your first reply, the logic of having the back of the heel mortised a couple of millimeters deeper than the front. I would like to do it that way.
What I’m trying to find is the heel angle necessary to get there. Your second answer, that 85 degrees puts the heel parallel with the ribs, means that a lesser angle (83 degrees) would cause the opposite of what you want to achieve. So is a heel angle somewhere around 87 degrees required to achieve the mortise that you recommend?
Thanks,
violinarius Member
Posted: Thu Nov 06, 2008 11:19 pm Post subject: |
| Chris Knowlton wrote: | I understand, after your first reply, the logic of having the back of the heel mortised a couple of millimeters deeper than the front. I would like to do it that way.
Thanks,
Chris |
"You seem to be having trouble visualizing this, may I suggest a pencil and paper, along with a compass to draw a life size drawing as an aid."
Hey where have I heard that before? Oh yes, my teacher use to have us do that. Worked everytime.
When in doubt get the pencil lead out!
Because you are struggling with this, perhaps a full scale drawing will give you insight into other things more than just the angle needed.
Make some cutouts of the neck heel with variuos angles, and see how they line up, and then you will see that the angle that Michael suggested, will work the way he said it would. |
Posted: Fri Nov 07, 2008 1:11 am Post subject: |
Hi violinarius.
Thank you for your concern but I do understand the geometry. I guess I've been wording my posts poorly. I have been following the Johnson and Courtnall book which recommends 85 degrees for the heel angle. Michael says that 87 degrees is the way to go. I accept and embrace this and his reasons why.
Michael also said that 85 degrees would give you an even mortise depth. What I am trying to figure out is: What happens to the builders that follow Wake, Brown, and Strobel and cut their heel at 83 degrees. If 85 degrees sets the heel parallel with the ribs, these makers must be screwed when it comes time to set the neck. The back of the heel would be set to a lesser depth than the front.
Posted: Fri Nov 07, 2008 3:47 am Post subject: |
| Without looking I shouldn't guess this, but some people, especially in the period when Wake would have been writing, have used a neckset more aggressive than we use now. I wonder if looking at Wake would confirm that. That would be with a slightly higher bridge, and deeper insert (the distance between board and top at the heel). |
