mapleleaf_gal Member
Posted: Thu Oct 16, 2008 3:26 am Post subject: pictures (bad ones) of finished violin |
i will try to retake some better photos in the near future.
this one looks weird because the camera was at an awkward angle making the upper bouts look just as large as the bottom ones.
enjoy!  _________________ http://sgwhiteviolins.googlepages.com/home |
Posted: Thu Oct 16, 2008 4:41 pm Post subject: |
A beautiful soft and lovely color.... real eye candy.
Bravo! |
Gantafistor Junior Member
Joined: 29 Apr 2008 Posts: 16 Location: Québec, Lac-St-Jean
Posted: Fri Oct 17, 2008 12:59 pm Post subject: |
Hello, I congratulate for the violin, nice varnish by the way. But isn't the fingerboard a bit at the right from the center? Or maybe that is only because, like you explain, of an awkward angle of your camera? And at last, which model did you use for the violin?
Continue your nice work! Greetings
Ganta |
M.Lange Member
Posted: Fri Oct 17, 2008 2:49 pm Post subject: |
Hello,
looks like some very nice, clean work!
I particularly like the varnish.
When you take better photos, try to do it from a greater distance. You will get less distortion that way.
And don't forget to take one of the scroll.
Matthias |
Posted: Sat Oct 18, 2008 1:55 am Post subject: |
| Gantafistor wrote: | Hello, I congratulate for the violin, nice varnish by the way. But isn't the fingerboard a bit at the right from the center? Or maybe that is only because, like you explain, of an awkward angle of your camera? And at last, which model did you use for the violin?
Ganta |
the fingerboard is perfectly centered. it is just the angle of the camera. i literally took 1.5 minutes to snap these photos with zero light and a tripod. not by choice, it was just my only option at the time. i was also taking them outside and had the violin propped up on a chair.
it is a strad model.  _________________ http://sgwhiteviolins.googlepages.com/home |
Posted: Mon Oct 20, 2008 1:41 am Post subject: |
| A very handsome violin! |
