72bluebird Junior Member
Joined: 20 Jan 2021 Posts: 1 Location: Canada, Quebec, Baie-D'Urfe
Posted: Sat Jan 23, 2021 7:32 pm Post subject: Bridge recommendations for a dull Fiddle? |
A dull fiddle... it needs to be played pretty close to the bridge, and tends towards brassy and muted, especially on the A. With the current setup, I have optimized the A, which now means the D needs to be coaxed to a full tone (not "easy"). G is flabby, and E is OK but thin.
I would like to improve the overall volume, and get a more even, brighter tone.
I have two blanks, one has a "drop tone" about a tone higher than the other.
Thin at the top is what I have in mind (~1.2mm), and not much change to heart or kidneys.
Thin at the bottom, or thick? Different authors say different things.
Narrow ankles, or not? I have heard narrowing the ankles lowers the tone of the bridge.
Michael Darnton says too thick in the middle/waist = nasal
Hutchins says large kidney and heart dulls a shrill tone.
Reichers says a small heart = harder tone.
Thoughts on crotch arches?
Thanks in advance for any ideas. |
Posted: Mon Oct 04, 2021 6:24 am Post subject: bridge for dull fiddles |
Not exactly on topic but this refers to dull fiddle sounds. In Violinist.com there is a long survey of violin strings from gut strings to modern . Jean Dubuison is the writer . For example he mentions loud strings and others agree that Zyex strings are loud or louder . There is a variety of string influences that may combine better with your bridge.
Is the drop tone phrase about dropping a bridge on a hard surface? I discovered that myself by accident but there may be something new . Luthiers probably knew all about that ages ago . |
Henrik Stromberg Junior Member
Joined: 07 Sep 2021 Posts: 10 Location: Solna, Sweden
Posted: Thu Oct 28, 2021 2:08 am Post subject: Re: Bridge recommendations for a dull Fiddle? |
| 72bluebird wrote: | A dull fiddle... it needs to be played pretty close to the bridge, and tends towards brassy and muted, especially on the A. With the current setup, I have optimized the A, which now means the D needs to be coaxed to a full tone (not "easy"). G is flabby, and E is OK but thin.
No idea yet!  _________________ I'm a member of https://musescore.com/our-products family |
Posted: Sat Feb 26, 2022 7:15 pm Post subject: Bridge for a dull fiddle |
Has the soundpost been adjusted (or changed ) yet ?It sounds like a better soundpost will improve what you have there .If the post needs to be longer (to improve the G string ,obviously )then you need a new soundpost . The practical running order of changes needs to be followed . I don`t think a new bridge will overcome a soundpost fault .Anyway add that to the recipe to understand what you have .Also think about good strings as a minimum to give you a chance .You may learn a lot with a bad (or unhappy ) violin , but let`s not condemn it just yet .
The topic has gone dead but it`s a pity to leave cadavers of dead topics lying around the forum . Cadavers can be pronounced Cadiver which sounds much better .
I tried to learn Russian once and compared the phrasebooks for French with phrasebooks for Russian. The French books had discussions about cheese and wine .(Imaginary scenarios ). The Russian books had sentences like "I think he`s been dead for some time .He`s frozen solid ".Just a different emphasis reflecting their weather . |
