Joseph Leahy Member
Posted: Tue Feb 03, 2015 3:45 pm Post subject: nut or needle files |
Is anyone using the nut files (see Item #87-970 at https://www.violins.ca/tools/tools_files.html or are you using a needle file for forming the string slots? If so, which one?
My go to needle file is damaged so need to buy something new.
Thanks.
Joe |
Posted: Tue Feb 03, 2015 4:34 pm Post subject: needle files |
A few years ago I bought a very fine (small) needle file at the VSA Conference from the International Luthiers booth, and it is a godsend for doing nut string slots (and bridge too). If I use the finest end it makes a slot smaller than the width of an e string, and up toward the middle, nice makes slot for g string. Its nice to know you won't have rough edges inside the groves. Its about 4" long and only 1-2mm at the blunt end. I don't see it here, but it would probably be like the smallest they show here, in an extremely fine cut. _________________ Dave in the Blue Ridge
Joseph Leahy Member
Posted: Wed Feb 04, 2015 1:34 pm Post subject: Re: needle files |
Thanks Dave
I'll pick up something similar to yours.
Joe |
Posted: Wed Feb 04, 2015 8:33 pm Post subject: |
Hi joseph... I have not found anyone in the general marketplace that carries a good file small enough. My original was a "mouse tail" file ... that's smaller than a rat tail, that I had purchased from Heinl... last I checked they did not carry them, but that was a few years ago.
I would measure the thickest string diam that you will be fitting and then pick one from Lemuels list in the section Grobet swiss precision needle files ... round ones.
The cost is not cheap, but they last a long time... mine is now over 10 yrs old.
wm_crash Member
Posted: Wed Feb 04, 2015 9:25 pm Post subject: |
Howdy,
This is the narrowest round file I've come across is at 1.6 mm:
http://www.ottofrei.com/Files-Round-Parallel-4X1-16-Inch-1.6MM.html
Other than that, a feather file normally used to sharpen japanese saws would leave an even narrower groove. Just run a search for "japanese feather file" and a ton of them will show up. Suffice to say that there is a diamond version to these files but they don't leave as clean of a groove as the cut files.
Not sure if the teardrop profile has any merit, but it may:
http://www.ottofrei.com/Pippin-Hand-Files/
cheers,
Cosmin |
kjb Super Member
Posted: Thu Feb 05, 2015 10:47 am Post subject: |
| the needle file is that the same as a mouse tail? |
Posted: Thu Feb 05, 2015 5:47 pm Post subject: |
Pretty sure this is the one i'm using (and it works great for me) ....
https://www.internationalviolin.com/ProductDetail/t47_swiss-needle-file-round-4-cut-0 _________________ Dave in the Blue Ridge
Posted: Thu Feb 05, 2015 5:50 pm Post subject: |
| A mouse tail is one type of needle file. I have a pretty small one from IVC (same one Dave linked to), but I now use a home made nut file. I found a piece of 1 inch by .035 inch (0.9 mm) band saw blade about six inches long. I rounded about an inch and a half of one edge at one end, then filed "teeth" on it. I used a triangular file to cut negative rake grooves, not very deep. It cuts fast enough and leaves a very smooth finish on both nuts and bridges. I've had to sharpen it once, after I used it on a bone guitar nut. I use a very small knife file for the e string grooves. |
kjb Super Member
Posted: Fri Feb 06, 2015 1:31 pm Post subject: |
| thanks. |
byacey Member
Joseph Leahy Member
Posted: Tue May 12, 2015 1:46 pm Post subject: |
Thanks for the reply. I ended up purchasing the Nut Files, SET - E,A,D,G (https://www.violins.ca/tools/tools_files.html) and a Needle-File, 1.5 x 55mm, Cut#2 which is listed on the same page. I think I've got everything covered for now. I periodically do a bit of work on guitars (mostly my own) so may consider the StewMac ones in the future.
Thanks again for the response.
Joe |
byacey Member
Joseph Leahy Member
Posted: Wed May 13, 2015 12:36 pm Post subject: |
Thanks for the link. They look nice. I'll save it for future reference.
Joe |
John Masters Junior Member
Posted: Thu May 14, 2015 2:06 pm Post subject: nut or needle files |
Years ago Howard Core sold "mousetail files." He does not usually drop discontinued items, and it is worth a look.
They were not very expensive. I recall they were pretty sharp at the tip, and I am sure they were much smaller than a mm there. But they are brittle, so one must be carefull about breaking them
I need to order more for myself.
Carl Becker gave me a nice hint for a conventional triangular file. Just hone the tip to make a triple "knife edge." it is very nice for setting precisely on a divider mark. Carl had a lot of GOOD ideas, of course. |
