Harmonics on A and E strings
PostPosted: Wed Jun 04, 2014 10:25 pm    Post subject: Harmonics on A and E strings Reply with quote
I'm stumped -- I've been playing this violin almost daily for about 2 years, fitted with Obligato light strings. This past couple days its developed an octive harmonic on both A and E strings as you move up into 3rd position, and gets pretty bad when you're playing nearly an octive above the open string note. For instance, on the E, as you approach B, C, and D in third position the harmonic gets worse.
I've swapped out strings, tailpiece, removed the chinrest, still getting harmonics. Fingerboard, bass bar, bridge all look good. No sign of any open seams anywhere. This was a fine playing violin, I've done nothing to it until today when it really got bad, and I've run out of things to look at. Any clues out there? Weather maybe (hoping so)?
PostPosted: Fri Jun 06, 2014 8:48 pm    Post subject: Harmonics Reply with quote
I've moved the bridge about 2mm today and no major change in the situation.
DonLeister
PostPosted: Sat Jun 07, 2014 5:29 pm    Post subject: Reply with quote
Tried a different bow?
PostPosted: Sun Jun 08, 2014 9:21 am    Post subject: Harmonics Reply with quote
Don, you're a gem! I now have a new favorite bow!! At least for the time being, the harmonics are gone.
PostPosted: Sat Jun 21, 2014 9:17 pm    Post subject: harmonics Reply with quote
Its back, doesn't matter which bow. I may rework the fingerboard relief on the e and a side, lower the fb from the nut to the end of the neck perhaps .2mm or so. its kinda flat, and may be the source even though I can see daylight under the strings when playing the affected notes. At least that will be eliminated as a possible source. It perhaps should have been the first thing to do...Occam's Razor - you know.
PostPosted: Sun Jun 29, 2014 8:48 pm    Post subject: Harmonics Reply with quote
Not much change, scooped out fingerboard a bit, no change, but now the E is a bit clearer, as is the A, but hearing some harmonics on the D now. I'm completely flabbergasted. Looked inside with mirror, bass bar seems intact, nothing looks out of place, soundpost looks like a nice fit, can't see anything there. All the fittings have been changed out and back, no change. Only thing haven't swapped out is the pegs, but I guess that's all that's left. This violin sounded great up to now, made it two years ago, two seasons in local orchestra, no problem.
DonLeister
PostPosted: Sun Jun 29, 2014 10:04 pm    Post subject: Reply with quote
Can you describe the harmonics more?
PostPosted: Mon Jun 30, 2014 7:27 pm    Post subject: Harmonics Reply with quote
They're showing up as a full octave below the note being played, and occur mostly when playing --- E on the A string and A on the E string (second finger in third position) are most pronounced.
DonLeister
PostPosted: Mon Jun 30, 2014 8:26 pm    Post subject: Reply with quote
The open strings are vibrating sympathetically?
I usually think of harmonics as higher in pitch the stopped note.
PostPosted: Mon Jun 30, 2014 9:24 pm    Post subject: harmonics Reply with quote
This evening, it sounds only like harsh overtones, but still when playing higher on the strings. It seems to change, and could be damp weather, who knows. I have NOT changed the bridge, fingerboard, pegs. I'm going to slip another bridge in just to see if it goes away. I'm running out of things to try.
PostPosted: Tue Jul 01, 2014 7:52 am    Post subject: Reply with quote
I have heard of this sort of thing before, but I can't recall where. Some players can do it deliberately, and I seem to remember reading about a woman who had learned to do it well enough that she could play melodies an octave below the normal register of the violin.
I don't understand how it works...I think "harmonic" is as close to a correct description as I would know to give, even though I agree that harmonics are usually higher, not lower. Perhaps someone else will remember this phenomenon and call it by a more proper name.
Perhaps, in reality, it is some sort of Tartini tone, since it is causing a fundamental lower than the violin is really able to play? Psychoacoustics, anyone?
JG
PostPosted: Tue Jul 01, 2014 3:50 pm    Post subject: Reply with quote
Maybe some kind of combination tone? You sound two notes (or one note plus a sympathetic vibration), and then hear a low pitch whose frequency is the difference between the other two. We get this sometimes on electric guitar. Can be fun or irritating.
http://en.wikipedia.org/wiki/Combination_tone
Looks like Chet is on the right track with "Tartini tone".
PostPosted: Tue Jul 01, 2014 5:07 pm    Post subject: Reply with quote
I think in ham radio this (or something like it) was called "heterodyne"--and in water it causes "rogue waves"...but neither of those help the OP any. Sorry.
PostPosted: Tue Jul 01, 2014 9:09 pm    Post subject: Harmonics Reply with quote
The problem is resolved. The change in its behavior was only recent, so I was looking for something that might have happened to it in the last couple months. It was something I had ignored hoping not to have to go inside (and hoping not the culprit).
I had glued a small weight inside the belly when I first made this violin to cure a sound problem. It worked great for the first nearly two years. It could be that the violin has aged with play and time. Anyway, the weight is removed, problem gone.
byacey
PostPosted: Thu Jul 31, 2014 12:18 am    Post subject: Reply with quote
A sympathetic vibration? I was going to suggest something wasn't glued down tight, but I never would have guessed a weight inside the instrument!
Bill
