Peg Reamers
terryc
PostPosted: Mon Apr 07, 2014 9:09 am    Post subject: Peg Reamers Reply with quote
Interested in purchasing a peg reamer and wanted to know if anyone has an opinion on blade type.
Seems to be the spiral type, and then there are those of a more straight veined blade. Also noticed a modified version of the straight veined style with 1/3 of the shaft flat with no cutting blade. They claim it provides a more accurate cut.
Any advise or observations would be appreciated.
Terryc
Mikes
PostPosted: Mon Apr 07, 2014 9:38 am    Post subject: Reply with quote
Hi Terry,
Go with the straight blade type. The spiral reamers tend make the hole not round. Good luck!
Mike Spencer
PostPosted: Mon Apr 07, 2014 10:52 am    Post subject: Reply with quote
Agreeing with that.
Where did you see the kind with a flat side, that I've never seen before?
terryc
PostPosted: Mon Apr 07, 2014 1:13 pm    Post subject: Reply with quote
Thanks guys for getting back and happy we have a consensus on the straight blade type.
I saw it on but can now only locate the link for a cello but the one I was looking at was for a violin.
Here is the link:
http://www.ebay.com/itm/CELLO-PEG-HOLE-REAMER-FOR-VIOLIN-MAKER-/400586619418?pt=Guitar_Accessories&hash=item5d44d2ba1a
Thanks again,
Terryc
PostPosted: Mon Apr 07, 2014 7:12 pm    Post subject: Reply with quote
That reamer is not flat-sided. It does not have cutting edges all the way around and is what you want if you desire round holes. I have made a few flat-sided reamers that work pretty well. One advantage is that they will cut both ways. That is sometimes also a disadvantage. But you can't buy one, you have to make your own or get a machinist to do it.
I have both spiral and straight and prefer the spiral for most holes. It certainly DOES make round holes. There are a few places where straight works better and they are a little cheaper.
terryc
PostPosted: Mon Apr 07, 2014 8:27 pm    Post subject: Reply with quote
Now I am really confused. Let me clarify, did not mean "flat" it is round but 1/3 of it has no cutting blade. In your opinion, does the 1/3 round have any merit? (Please see link above)
Thanks
Terryc
Cliff Green
PostPosted: Tue Apr 08, 2014 8:24 am    Post subject: Reply with quote
The non cutting segment of the reamer allows you to shift the hole laterally with somewhat better control than a reamer with 360 blades. I agree with LP's comparison of straight and spiral reamers. If I only had one it would be straight but the spirals do cut nicely.
terryc
PostPosted: Tue Apr 08, 2014 1:37 pm    Post subject: Reply with quote
Cliff,
Appreciate the explanation on the reamer with the smooth side.
Thanks
Terryc
PostPosted: Tue Apr 08, 2014 2:40 pm    Post subject: Reply with quote
My objection to the spiral reamer wasn't about round holes, but the tendency for it to suck itself in under certain circumstances. But I used a very early one, one of the first run, and Herdim's tools in that era weren't always useable.
PostPosted: Tue Apr 08, 2014 5:43 pm    Post subject: Reply with quote
terryc wrote:
Cliff,
Thanks
Terryc
In addition, a reamer with evenly spaced cutting edges all the way around will chatter and not cut a smooth hole. Countersinks do the same thing. My best countersink has only one cutting edge.
My spiral reamer is relatively new and does not seem to have the self-feeding tendency. It is not as good for correcting hole alignment as the straight-fluted one.
Mikes
PostPosted: Wed Apr 09, 2014 10:34 am    Post subject: Reply with quote
[quote="L P Reedy"]
Ok LP Reedy nailed the issue that I was thinking of which as he correctly states is associated with reamers that have cutting edges all the way around. Sorry for the memory lapse!
Either way good luck reaming is not a difficult procedure, go slow and keep an eye out that the reamer isn't drifting out of alignment.
Mike Spencer
PostPosted: Mon May 05, 2014 7:37 pm    Post subject: Reply with quote
I just encountered an interesting situation. I have a horribly-treated old fiddle in for repair. It had a set of totally non-functioning Casperi pegs. When I got them out I found that it had previously been equipped with bass-style geared tuners. All of this had resulted in holes that were oversized and two of them "doubled." I found, in reaming for bushings, that the spiral reamer DID NOT work. I don't know why, but all it would do was grab. The straight reamer had trouble but was much better. Two of the holes were so bad that I used a cello reamer.
There are other problems almost as bad, but we won't get into them.
PostPosted: Mon May 05, 2014 9:27 pm    Post subject: Reply with quote
LP... Interseting.... I am curious how you dealt with the double holes.
... But I'll start a new topic on this... Cheers, Mat
