working flamed maple
kjb
PostPosted: Thu Mar 14, 2013 5:05 pm    Post subject: working flamed maple Reply with quote
when working with it it tends to have rolling hills on the harder flamed part, when scraping is there a technique that help prevent that. I am now just going 90 degrees to the hump to bring it down then with for finish . thanks
kubasa
PostPosted: Thu Mar 14, 2013 8:46 pm    Post subject: Reply with quote
I'm thinking outloud here so this isn't necessarily advice. -- I don't know that I necessarily angle at 90 degrees when I'm trying to even out the hills and valleys. I think I do it at around 45 degrees.
Sometime ago, I think I remember Michael posting a photo of an older instrument with these hills and valleys on it. I have to wonder how common these waves were on older instruments.
James
TimRobinson
PostPosted: Thu Mar 14, 2013 8:49 pm    Post subject: Reply with quote
James
FWIW I have a Georg Leeb from 1785 with a nicely flamed one piece back. The undulations are quite distinct. I have often wondered if they increased with age.
Tim
actonern
PostPosted: Thu Mar 14, 2013 9:39 pm    Post subject: Reply with quote
For me, working in angled sunlight is my best friend in this situation.
The sun throws such hard shadows that you can see the smallest undulation in stark relief. Then work the scrapers so that the hills are clipped off and the plate flat.
But I also think flat plates with a vigorous curl will re-introduce wavyness over time, particularly moving back and forth through humidity cycles.
Janito
PostPosted: Thu Mar 14, 2013 10:02 pm    Post subject: Reply with quote
At the 2010 (?) VSA, there was a fantastic Burgess viola on display - amazing varnish on a super rippled back.
Embrace the ripple.
kjb
PostPosted: Fri Mar 15, 2013 8:19 am    Post subject: Reply with quote
I was wondering if it enhanced the 3d effect
actonern
PostPosted: Fri Mar 15, 2013 11:44 am    Post subject: Reply with quote
like this???
http://www.youtube.com/watch?v=iEnCKEfSgUM
PostPosted: Fri Mar 15, 2013 11:53 am    Post subject: Reply with quote
A lot of makers work hard to get that ripple. The easy way is wet the wood, then scrape with your scraper very vertical and in line with the curls so that it falls into them. Once you have a good crude ripple going you can go back and carefully smooth it.
kjb
PostPosted: Fri Mar 15, 2013 4:23 pm    Post subject: Reply with quote
ok I won't worry about getting rid of it. thanks
