Light for seeing interior of violin
PostPosted: Sat Jan 07, 2012 9:54 pm    Post subject: Light for seeing interior of violin Reply with quote
I was shopping the other day and saw what is labeled as a "Bore Light" made by Winchestor (at least that's the logo on it). It uses an LCD light and fits inside a 7mm bore. It has a 6" flexible neck, uses an AAA battery, is VERY bright. Fits through the lower part of the violin "F" hole very nicely. Cost about $5, and found it at the Wal-Mart sporting goods area.
Always on the look out for inexpensive alternates to expensive tools. At the link below, it lists for $2.99 on-line but then there's shipping. Make sure you get the one 715717.
http://www.midwayusa.com/product/715717/winchester-flexible-led-bore-light
Joseph Leahy
PostPosted: Sun Jan 08, 2012 6:15 pm    Post subject: Re: Light for seeing interior of violin Reply with quote
Thanks Dave, just what I was looking for.
___________
Website: www.leahyviolins.com
PostPosted: Mon Jan 09, 2012 12:04 am    Post subject: Reply with quote
Here is what I use ( the 16" bendalight) ...
http://violins.ca/tools/tools_luthier.html
It has a head diameter of 5mm (3/16 ") and 16" overall
It is not LED but is nice and bright and you can flex the shaft to any shape. fits easily anywhere thru most of the f hole.
PostPosted: Mon Jan 09, 2012 5:58 pm    Post subject: Reply with quote
Mat,
I have one of those, admittedly over ten years old. It worked great when new, but due to the really crappy switch mechanism it is now hit or miss whether it will light up or not. I have an LED light that I put together from one of those stick-on lights and some wire with a little soldering that works well. You do have to know what you are doing, though. I see more and more of the type Dave described and they keep getting cheaper.
johnmasters
PostPosted: Sat Jan 14, 2012 2:56 pm    Post subject: Light for seeing interior of violin Reply with quote
I don't like thick metal things. My hobby shop has all sorts of miniature lamps for use in model railways. The largest I found were about 3-4mm in diameter and a centimeter long. All seem to be 12 volts.
I have a 12 volt powerpack whose plug I cut off and solder two of the large lamps. This plugs into a wall receptical with its own switch. It works fine and can be snaked anywhere inside the violin.
Will L
PostPosted: Sat Mar 24, 2012 12:27 am    Post subject: Reply with quote
My experience with the switch of the Bend-a-Light is the same as LP. Otherwise, I like it a lot.
DonLeister
PostPosted: Sat Mar 24, 2012 9:23 am    Post subject: Reply with quote
I got that light that light that Dave did, it is bright and another good thing is that it is directional and pretty even. I shine it at the mirror inside the violin and it lights up the area I want to see, usually the post, also the bulb doesn't stick out so there is no glare in the line of sight.
The switch is a pushbutton type with really strong spring on it, it makes me hope it will last.
